You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Call Preservation W/H.323 GW and CCM
If CallManager fails,
1. What happens to a call from the PSTN through H.323 GW ?
1b. With and without GateKeeper.
2. What Happens to call when running over IPWAN ?
I am interested if the voice path is perserved, and maybe the signal path is lost. Will call remain up if CCM fails ?
What a gate failure, Iassume the PRI goes down and the channel disconnects. Will the Gateway perform any signal freezing, then switch to secondary gateway.
Thanks for all you consideration..
Steve
  • Other Collaboration Voice and Video Subjects
1 REPLY
Re: Call Preservation W/H.323 GW and CCM
Steve,
Calls controlled via H.323 will fail within about 30s should either of the signalling end-points fail (e.g CallManager). This affects intercluster trunks and calls through gateways. This is an H.323 issue with or without a gateway.
Call preservation (i.e. keeping the audio path up) only works for skinny devices and MGCP gateways.
Justin
147
