Call Queuing issue
We are facing an issue with queuing of Calls. We are running CRA 3.3 and CCM 3.3. The calls are getting queued when the agents are busy or in not ready state. The queuing part works fine. But whenever the caller presses any key while hearing the queue prompt the caller hears silence and the prompt stops. Will appreciate any assistance in solving this issue.
Silver
Re: Call Queuing issue
Have you defined any action to be performed after getting the dtmf input, while on queue? Breifly explain your script.
Yogi
Bronze
I suspect that the Play Prompt inside the Queue step as the Barge-in property set to Yes, this means the caller can interrupt the prompt. Try setting the Barge-in property to No and let me know the result.
If still problem persists, please explain your script.
Venkat
92
