call rejected
What´s problem this call? They see:
.May 9 17:08:49.979: Sending Complete
.May 9 17:08:49.979: Bearer Capability i = 0x8090A3
.May 9 17:08:49.979: Channel ID i = 0xA98384
.May 9 17:08:49.979: Called Party Number i = 0x80, '1300', Unknown/Unkn
own
.May 9 17:08:50.015: ISDN Se1/0:15: RX <- CALL_PROC pd = 8 callref = 0x8761
.May 9 17:08:50.015: Channel ID i = 0xA18384
.May 9 17:08:50.023: ISDN Se1/0:15: RX <- ALERTING pd = 8 callref = 0x8761
.May 9 17:08:50.023: Channel ID i = 0xA18384
.May 9 17:08:50.023: Locking Shift to Codeset 5
.May 9 17:08:50.023: Codeset 5 IE 0x32 i = 0x80
.May 9 17:09:10.087: ISDN Se1/0:15: TX -> DISCONNECT pd = 8 callref = 0x0761
.May 9 17:09:10.087: Cause i = 0x8095 - Call rejected
.May 9 17:09:10.107: ISDN Se1/0:15: RX <- RELEASE pd = 8 callref = 0x8761
.May 9 17:09:10.111: Cause i = 0x809080 - Normal call clearing
.May 9 17:09:10.115: ISDN Se1/0:15: TX -> RELEASE_COMP pd = 8 callref = 0x076
1 ACCEPTED SOLUTION
Silver
Re: call rejected
THe ISDN switch is rejecting the call but it does not say on what parameter. In my experience it could be they are expecting an ani for the call and they are not getting it.
Silver
Re: call rejected
Re: call rejected
Exist a way in the router to interpreter this ANI or command relative to a tecnology ISDN?
Re: call rejected
What model gateway are you using? Is it CAT OS or IOS?
Re: call rejected
I´m using IOS for solutions.
510
