Call restriction
Preface:
There is Cisco 3745 connected to PSTN (with network module NM-HDV-E1-30). There are IP Phones connected to Cisco 3745 via SCCP ( Cisco 3745 is CallManager Express). Several GateKeepers (non-Cisco) connected to this Cisco 3745 via H323
Objective:
How can I restrict long-distance call (prefix 98T) from all IP phones and from all GateKeepers (but local call 98903T, 98905T, 98916T, etc are allow). But serverl IP phones allow making call between 9-00 and 21-00. In other time all calls have to prohibit. If someone know pin code then he may call anytime.
Silver
Re: Call restriction
Since you want to allow 98903T, 98905T, 98916T, add pots dial-peers for these patterns. Do not create any pots dial-peer for 98T, so no long distance calls will be allowed from this CME router/gateway.
Here is a relevant sample config for what you want to achieve, which might help!
telephony-service
after-hours block pattern 98
after-hours block day mon 21:00 9:00
after-hours block day tue 21:00 9:00
after-hours block day wed 21:00 9:00
after-hours block day thu 21:00 9:00
after-hours block day fri 21:00 9:00
after-hours block day sat 21:00 9:00
after-hours block day sun 21:00 9:00
login timeout 180
ephone 10
pin 1234
dial-peer voice 98903 pots
destination-pattern 98903T
port 1/0:15
dial-peer voice 98905 pots
destination-pattern 98905T
port 1/0:15
dial-peer voice 98916 pots
destination-pattern 98916T
port 1/0:15
Yes I know about it, BUT I have to create dial-peer 98T, because several IP phones (not only CME, they may be from GateKeeper) can place long distance call.
I must divide phones who can place long distance call and who can't
How I can do it?
I've found additional information about CME restriction:
Call blocking is supported on IP phones only and not on analog FXS phones.
You can use COR (class of restriction) to block or allow calls coming from FXS ports and IP phones. It can be used in conjuntion with CME dial peers.
This link provides information about COR.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080aec.html#1336666
Hope this helps.
thank you for your answer.
Yes, I saw that document. But I need COR + Time Restriction. How can I do that I dont know.
132
