Call routing & Auto Attendant
gruiz
I have the following configuration in my gateway:
voice-port 0/0
connection plar opx 2500
caller-id enable
dial-peer voice 10 voip
destination-pattern 2500
session target ipv4:192.168.9.201
dial-peer voice 1 pots
destination-pattern .T
port 0/0
When a call gets to the FXO port it will ring in the IP phone with extension 2500. This works perfect. Now, if I change the extension of the IP phone to the one of the Auto Attendant; when I get the interactive menu of the AA and I press any digits for any of the available options the AA appears that is not getting any digits. I know that with PLAR OPX I can't send any digits until the call is established, but when the AA answers the call, the call itself is established. When I try the AA using local extensions (not using the gateway) works perfect.
Any insights on this issue will be appreciated.
Gabriel
j.ayres
Gabriel
You need to enable dtmf-relay h245-alphanumeric on your voip dial-peer so that the AA receives the digits out of band.
Hope this resolves the problem,
Justin
Vance Krier
Level 4
Level 4
Hi Gabriel,
I think you need to turn on dtmf-relay on the voip dial-peer. Something like 'dtmf-relay alpha' or 'dtmf-relay signal' should do fine. I usually use alpha, but signal works better if you need to be able to determine tone length, like how long a user pushed and held the 4 key or whatever. Here's a decent link:
http://www.cisco.com/warp/public/788/AVVID/unity_cm_dtmf_prob.html
Good luck,
Vance
j.ayres
Gabriel
Justin
