Community Member
Call Routing Dial Peer
Hi. I have a problem. I have a UC540. Configure it to connect to a CUCM calls through a VPN, the problem is that I need to call out a loopback IP and not the public IP.
The configuration is as follows:
we need to call to the extensions 100 to 299:
dial-peer voice 2013 voip
description Llamadas al Call Manager
destination-pattern [1-2]..
session target ipv4:10.253.252.5
dtmf-relay h245-alphanumeric
codec g711ulaw
The connetion is through VPN. I put a DEBUG PACKET IP and dial the call and this is what showed
UC540# csim start 100
001176: Sep  4 22:32:12.577: IP: s=190.50.50.205 (local), d=10.253.252.5 (FastEthernet0/0), len 44, post-encap feature, FastEther Channel(3), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
001177: Sep  4 22:32:12.577: IP: s=190.50.50.205 (local), d=10.253.252.5 (FastEthernet0/0), len 44, sending full packet
I need to route the call from a private IP or loopback.
UC540# Show ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            190.50.50.205  YES DHCP   up                    up
In0/0                      10.1.10.2       YES unset  up                    up
FastEthernet0/1/0          unassigned      YES unset  up                    up
FastEthernet0/1/1          unassigned      YES unset  up                    up
FastEthernet0/1/2          unassigned      YES unset  up                    down
FastEthernet0/1/3          unassigned      YES unset  down                  down
FastEthernet0/1/4          unassigned      YES unset  up                    up
FastEthernet0/1/5          unassigned      YES unset  up                    up
FastEthernet0/1/6          unassigned      YES unset  up                    down
FastEthernet0/1/7          unassigned      YES unset  up                    up
FastEthernet0/1/8          unassigned      YES unset  up                    up
Dot11Radio0/5/0            unassigned      YES NVRAM  up                    up
Dot11Radio0/5/0.1          unassigned      YES unset  up                    up
Dot11Radio0/5/0.100        unassigned      YES unset  up                    up
Vlan1                      unassigned      YES unset  up                    up
Vlan100                    unassigned      YES unset  up                    up
Vlan200                    unassigned      YES unset  up                    up
Vlan300                    172.16.0.1      YES NVRAM  up                    up
NVI0                       10.1.10.2       YES unset  up                    up
BVI1                       192.168.1.1     YES NVRAM  up                    up
BVI100                     10.253.5.1      YES NVRAM  up                    up
BVI200                     172.16.31.1     YES NVRAM  up                    up
Loopback0                  10.1.10.2       YES NVRAM  up                    up
Is this posssible? For example using the BVI100 IP address.
Thank a lot
Everyone's tags (4)
1 REPLY
Hall of Fame Super Gold
You have not said which kind of VPN is that. Router will normally use the outgoing interface address.
Anyway, you can use h323 bind commands under the desired interface.
297
