call routing
I have a H323 voice gateway Vg200 with this following configue:
voice-port 1/1/1
input gain 14
output attenuation -6
description connection to PSTN
music-threshold -30
supervisory disconnect anytone
no battery-reversal
dial-peer voice 1000 voip
destination-pattern ...
progress_ind progress enable 8
max-redirects 10
session target ipv4:173.16.10.200
dtmf-relay h245-alphanumeric
when I call from PSTN :
PSTN call (( example telephonique N° 1234 ))>>> vg200 (( ring, the FXO cards hang up and lisen a dial tone )) >>> (( I compse the Directory number of the Ip Phone that I hope contact example DN 2020 )) >>> callmanager>>> IP Phone.
My probleme it's to eliminate the ring and the dial tone.
I wish dial the whole number to contact the ip phone :
PSTN call (( example call N° 12342020 ))>> vg200>>> callmanager>>> IP Phone.
thanks .
  • Other Collaboration Voice and Video Subjects
1 REPLY
Silver
Re: call routing
You need to have connection plar under your voice port.
connection plar 1234
When there is an incoming call on that port, the FXO will answer the call and then make a call to string 1234. You should have a VOIP dial peer for that number pointing to the call manager.
79
