Community Member
Call through gateway from different region
we have 3845 router and 2 E1 configured one as H323 and other as MGCP gateway. Both the gateway are in same region( Say A). The phone on the same region ( A ) has no issue in calling through both gateways. But the phone on the other region ( say B) can make call through MGCP gateway only. When i try through H323 gateway rings once and get disconnect automatically. Within the same region codec G711 is used and between the region A and B codec G729 is used.Please, Could any one help me to sort out this issue? Is it because of transcoding issue ? if so why this happenning only with H323 not with MGCP?
Bronze
Re: Call through gateway from different region
Your H323 gateway is probably using the G711 codec only. Your MGCP gateway will support multiple codecs automatically. In the H323 router setup the following:
Router#conf term
Router(config)#voice class codec 99
Router(config-class)#codec preference 1 g711ulaw
Router(config-class)#codec preference 2 g729br8
Router(config-class)#codec preference 3 g729r8
Router(config-class)#end
Then assign that codec class to each VOIP dial peer (incoming call leg):
Router(config)#dial-peer voice 2000 voip
Router(config-dial-peer)#voice-class codec 99
That should fix it
Please rate posts!
Community Member
Thanks a lot. It is working. Sorry for late reply.
136
