Call timer on Cisco IPT Environment
I am planning to implement a call timer on an enterprise cisco IPT environment. I want all outbound calls to be dropped say after 10minutes, cos most of my users are abusing the phone. I use AS5350 gateway to connect to the PSTN and run CCM4.1(3)
Can anyone help with the configuration or available 3rd party solution to achieve this?
Chuks
1 REPLY
Re: Call timer on Cisco IPT Environment
I don't know about "call drop" but you could implement "one-button" Extension Mobility, set Enforce Maximum Login Time to TRUE and set a time limit (between 1 Minute and 1 Week ins the range) and prevent Multiple Logins Here is a link to EM:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmfeat/fsem.htm
Another idea might be "time-based" COR using the Time Schedule feature with CCM 4.1(3), however this could really complicate your dial plan.
125
