Call Transfer CCM - Meridian
Currenly have a CCM (3.1) connected to a Meridian Option 81c (X11 rlse 22.46)using Q931. Since upgrading from 3.08 we have lost the facility to transfer. A meridian user calls an IP phone which in turn transfers the call to either another IP phone or Meridian and the call will drop out, although it works fine with the softphone ver 1.2.1.
Re: Call Transfer CCM - Meridian
What kind of gateway are you using with the CallManager that connects to the Meridian switch?
The router is a cisco 2611 IOS 12.1(5)YB2
Roger,
Why are you using YB software? Do you have an ADSL WIC? If not can you please try this on a different version of IOS, for example 12.1(5)T10 ?
Thanks.
Which system is handling the transfer. CCM has to have two lines on a set to transfer. On the M1 Opt. 81C it is handled by a card in the core of the switch. I use to install 21e-81c and some SL100 switches it has been about 14 months since I have messed with one and moved over to VoIP with CCM.
111
