12-16-2005 01:37 AM - edited 03-13-2019 11:34 AM
i have a problem with call transfering. Here a example for my problem:
Number 0170123456 calls from mobile the internal number 222. Number 222 wants to transfer the call from extern to number 333.
Now when i try to transfer the call, then i get busy.
In the telephony-service settings i configured
transfer local-consult
My Hardware is a 2801 and a 12.3.14T5 IOS Image.
Has anyone an idea what is wrong?
What i forgot, the transfer of internal to internal is ok.
Thanks for help
Christian
12-16-2005 03:03 PM
Add the external destination to a tranfer-pattern
e.g
telephony-service
transfer-pattern 9T
You can use more specfic transfer patterns if you want to restrict transfer destinations.
12-17-2005 03:32 AM
My problem is not the transfer to a extern destination. I cant transfer a incoming extern call to a other intern ephone...
12-17-2005 11:52 AM
Do a transfer-system full-consult under the telephony setup and have a transfer-pattern for eg 2... if you are using 4 digit dial plan with NXX ranges from starting from 2.
