call
I have a H323 voice gateway Vg200 with this following configue:
voice-port 1/1/1
input gain 14
output attenuation -6
description connection to PSTN
music-threshold -30
supervisory disconnect anytone
no battery-reversal
dial-peer voice 1000 voip
destination-pattern ...
progress_ind progress enable 8
max-redirects 10
session target ipv4:173.16.10.200
dtmf-relay h245-alphanumeric
when I call from PSTN
PSTN call (( example telephonique N° 1234 ))>>> vg200 (( ring, the FXO cards hang up and lisen a dial tone )) >>> (( I compse the Directory number of the Ip Phone that I hope contact example DN 2020 )) >>> callmanager>>> IP Phone.
My probleme it's to eliminate the ring and the dial tone, I wish dial the whole number to contact the ip phone :
PSTN call (( example call N° 12342020 ))>> vg200>>> callmanager>>> IP Phone.
thanks .
1 REPLY
Re: call
add this:
dial-peer voice 2000 pots
incoming called number .
direct-inward-dial
port 1/1/1
84
