Caller does not hear alert or message re number outside local calling area
I dial a number in the same area code, but outside the local calling area -- i.e., I dial 94411244 when I should have
dialed 818634411244. (9-local, 8-LD). Ring tone is never heard on the 7940; as soon as "To 94411244" is displayed, the screen is wiped clean to an on-hook indication. Placing the same
call on a directly connect PSTN station, I hear ring tone, a long pause then the intercept tones, then a message: "Your long-distance carrier cannot complete your call as dialed...". Dialing a flat-out wrong local number (e.g., 91234567) I hear the error message as I would expect.
CCM 4.1(3)SR2, SCCP 7940
3640 c3640-is-mz.123-8.T5.bin
H.323, PRI to Verizon
Possibly relevant config snippets:
voice call convert-discpi-to-prog
interface Serial1/0:23
no ip address
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
isdn map address ^9[2-9]......$ plan unknown type unknown
isdn map address ^9[2-9].........$ plan unknown type unknown
isdn map address ^91[2-9].........$ plan unknown type unknown
isdn map address ^9[49]11$ plan unknown type unknown
isdn map address ^9011 plan unknown type unknown
isdn map address ^81[2-9].........$ plan unknown type unknown
voice-port 1/0:23
bearer-cap Speech
dial-peer voice 1023907 pots
destination-pattern 9[2-9]......$
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 1/0:23
forward-digits all
The q931 debug looks like everything is proceeding correctly at the ISDN level, but the timestamps suggest the call is terminated long before the alerting and error message is heard on a POTS phone:
b7124r127-gw-3640-1#
Feb 1 14:39:32.120: ISDN Se1/0:23 Q931: Applying typeplan for sw-type 0xD is
0x0 0x0, Calling num 1303
Feb 1 14:39:32.128: ISDN Se1/0:23 Q931: Applying typeplan for sw-type 0xD is
0x0 0x0, Called num 94411244
Feb 1 14:39:32.128: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x2BAA
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838E
Exclusive, Channel 14
Calling Party Number i = 0x0081, '1303'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '94411244'
Feb 1 14:39:32.188: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref =
0xABAA
Cause i = 0x8282 - No route to specified network
Any ideas?
Green
Re: Caller does not hear alert or message re number outside loca
The Telco is the one which is dropping the call instead of playing the announcement which its ok to me, you may contact Verizon to instead of sending back a 0x8282 message back it plays the announcement.
(You can use CCM Annunciator feature also).
Thanks; I came to the same conclusion after thinking about it a bit, but haven't gotten around to calling Verizon yet. That's an exercise I'll leave 'til Monday.
--mike
I spent a hour or so with Mr Verizon this morning and he eventually confirmed that their switch (GTD5) could not provide the audible messages heard on an analog phone. There was some confusion toward the end when he said that if I held the call longer, I could hear the message, but since the 3640 disconnects in response to Verizon's Release Complete, that didn't make much sense to me. Bottom line -- I'm sending an e-mail to our users telling them that if this happens, they dialed incorrectly, please check the number and dial again.
146
