Caller ID display on FXO
I do have a basic h323 setup. A single phone line (w/ CLID enabled from provider) connected to my voice router on FXO port. I configured the router as follows:
Gateway
voice class h323 1
h225 timeout tcp establish 3
dial-peer voice 95 voip
description TO-CCM
destination-pattern ....
voice-class h323 1
session target ipv4:10.10.10.100
dtmf-relay h245-alphanumeric
dial-peer voice 25 pots
description TO-PSTN
destination-pattern T
port 2/0/1
voice-port 2/0/1
connection plar 2002
description H323 Pilot
caller-id enable
2002 is my own ip phone connected to the 10.10.10.100 CCM. everything is fine except caller ID. The phone line has CLID enabled, I have verified this by direct connecting a CLID capable normal phone set.
Whenever an external call comes to my IP phone it is still showing "from unknown number'. Anybody have any suggestion? what to check next ..? any troubleshooting steps..
Green
Re: Caller ID display on FXO
I have tried on both of the following combination
3825
12.4(7) sp services
####AND#######
3745
12.4(7) sp services
Please find attached debug outputs. I couln't find any output showing CLID.
Give it a try in your dial-peer to see if it helps.
description TO-CCM
voice-class h323 1
no clid strip
'no clid strip' will work only if 'clid strip' is set. IOS puts a a message for you, while i tried to configure this.
Could you post the below logs as suggested by gogasca?
debug voice ccapi inout
debug vpm signal
Silver
Depending on your telco, they might send the caller id during the first or second ring. Try changing this on the voice port and see if that helps. Here is the command
caller-id alerting ring [1|2]
Anup
I tried both 1 and 2. but nothing works. confused.?
Green
I checked the debug:
----- ccCallInfo IE subfields -----
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Jul 28 15:01:51.061: [2/0/3] get_fxo_caller_id:Caller ID receive failed. parseCallerIDString:no data.
We dont see any caller ID coming at voice ccapi level.
You must configure the alerting method when the Caller ID standard, specified by locale through the cptone command, is not Bellcore/Telcordia. (The one you are using is BELLCORE)
Jul 28 15:01:37.993: [2/0/3] htsp_start_caller_id_rx:BELLCORE
If you do not configure the alerting method, the default caller-id alerting ring 1 command is applied. The command that you enter is determined by the Bellcore/Telcordia or ETSI standard that your service provider uses for Caller ID.
Try upgrading to the latest IOS and give it a try with a different FXO port. I would contact the Service Provider to check the line.
//G
514
