02-04-2006 07:06 AM - edited 03-13-2019 12:04 PM
I am putting a IPT/IPCC Enterprise system in Cananda. I am using H.323 GW on 2851 router with IOS 12.3(11)T5 version with CCM 4.1(3)sr1.
Since we are doing an area code routing for our call center internally, it is critical to get ANI delivered to us. The problem is when callers call in from cell phones to the toll-free number we do not get the caller ID. Blelow is a "debug isdn q931":
Feb 4 08:51:23.550 CST: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8 callref = 0x011A
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE9808309
Exclusive, Interface 0, Channel 9
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x00C3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0xC1, '5073'
Plan:ISDN, Type:Subscriber(local)
Feb 4 08:51:23.562 CST: ISDN Se0/3/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x811A
Channel ID i = 0xA98389
Exclusive, Channel 9
Feb 4 08:51:23.922 CST: ISDN Se0/3/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x811A
Feb 4 08:51:27.604 CST: ISDN Se0/3/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x011A
Notice "Call not end-to-end ISDN, may have in-band info"
This toll-free number terminates locally on DID, when I call the DID instead of the toll-free I get the caller ID fine, below is the debug
Feb 4 09:03:26.006 CST: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0AC9
Standard = CCITT
Channel ID i = 0xE9808312
Exclusive, Interface 0, Channel 18
Calling Party Number i = 0x2183, '4165616329'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '5101'
Feb 4 09:03:26.018 CST: ISDN Se0/3/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8AC9
Channel ID i = 0xA98392
Exclusive, Channel 18
Feb 4 09:03:26.450 CST: ISDN Se0/3/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x8AC9
Is this definitely a Telco problem, or is it a gateway setting???
Thanks for any help!
Chris
02-04-2006 09:47 AM
Well, I see that 'call not end-to-end isdn' message a lot, does not seem to be a problem necessarily. The real issue here looks to be that the Q931 pkt coming in from the tool-free number has N/A instead of a calling party number. The carrier should be able to look at the messages they are sending and explain why they are doing that.
Mary Beth
02-06-2006 04:37 AM
Call the telco.
02-06-2006 05:19 AM
I did that Bell Canada is claiming it's not their fault, it's the Cell provider.
Chris
02-06-2006 06:20 AM
Hi Chris,
This certainly seems like a Telco problem.A couple of questions though.
Is Calling Party Number i = 0x2183, '4165616329' from the successful call, the Cell#?
The unsuccessful call terminates on:
The successful call terminates on:
Was this intentional? It would be helpful to call the same number using both methods to help prove to Bell Canada that this is their problem.If you could call the DID that terms the toll-free number directly it would sure prove your case.
We also use Bell Canada as our provider, so if there is any testing that I can do that would help you out,just let me know.
Take care.
Rob
02-06-2006 08:49 AM
Hi Rob,
The debugs are from the same cell phone, but I dialed different toll-frees, we have several. All the toll-frees behave the same way, we get ANI on local numbers from cell phones, but not on toll-frees, we get ANI on all calls from land phones.
Bell is trying to blame the cell provider.
Chris
02-06-2006 09:22 AM
Hi Chris,
This makes no sense does it.If calls from Cell phones directly to the DID number work fine (correct ANI) it would seem to indicate that the cell provider is sending the correct info.I'm guessing that the cell phone is not from Bell Mobility, so it is convenient to blame someone else. I have discovered that we have the same problem here and have opened a Ticket with Bell. I will let you know what the resolution is. If you need someone with a Bell Mobility cell phone to call your toll-free numbers let me know by emailing me at:
I would be happy to give you a hand proving this from my Bell cell phone.
Take care!
Rob
02-06-2006 10:59 AM
Thanks Rob,
Please let know the outcome. And after talking to Bell we called from Bell Mobile and ecountered the same issue as with Rogers. We've opened a new ticket to investigate it further.
Chris
