caller-id no working!! on VIC2-2FXO in china (124-24.T2)
at 124-24.T caller id is ok!!
but in 124-24.T2 caller id can't receive at phone.
cfg is the same:
voice-port 0/1/0
supervisory disconnect dualtone mid-call
cptone CN
timeouts interdigit 5
timeouts call-disconnect 5
timeouts wait-release 5
caller-id enable
try the all caller-id option,can't find the cause!!
caller-id alerting dsp-pre-alloc
caller-id alerting line-reversal
caller-id alerting pre-ring
caller-id alerting ring
at last I found the show voice port is different in 124-24.T and 124-24.T2,when the config is the same:
124-24.T:
Caller ID Info Follows:
Standard BELLCORE <<<
Caller ID is received after 1 ring(s)
124-24.T2:
Standard ETSI <<<xxxx
how can I change Caller ID Info Follows:
Standard ETSI ? I already used the cptone CN !!
Hall of Fame Super Gold
Re: caller-id no working!! on VIC2-2FXO in china (124-24.T2)
Configure any european cptone and check again.
Or complain to cisco to have the problem fixed.
it seems a very strange bug. I have open case and help for tac.
It happens all the time.
Cisco fixes something, but breaks something else.
but 124-24.T2 and 124-24.T are in the main version,in theory 124-24.T2 will only fix the old bug,but it seems bring the new bug.
As mentioned above, new bugs are often introduced in the process of fixing existing ones.
TAC answer: to fix a ISDN PRI bug,124-24.T2 has to change Standard ETSI even
using cptone cn,suggest downgrade to 124-24.T,but  we are using ssl vpn,124
-24.T has the bug CSCtb73337,we have go to 124-24.T2 to fix CSCtb73337,can't
using caller id a long time.
--we and cisco TAC are crazying for these voice bugs and ssl bugs,it seems
too many bug in cisco voice and security!
866
