Caller ID on FXO with MGCP
Hi Folks,
We are facing a problem with the reciving Caller ID on calls on FXO ports with MGCP.
When do a debug vpm signal i can see the FXO is recieving the Caller id from the provider but its not being passed to the IP phone.
voice-port 0/0/1
supervisory disconnect dualtone mid-call
supervisory custom-cptone UAE-CUSTOM-ALCATEL
supervisory dualtone-detect-params 1
input gain 14
timeouts call-disconnect 5
timeouts wait-release 5
timing hookflash-out 50
timing min-ring 62
caller-id enable
this is the configuration on the voice ports ...
guys please advice ..
thanks
Re: Caller ID on FXO with MGCP
Caller ID is not supported with FXO ports when using MGCP. See the following link for details. You will need to change the port to H323 to utilize caller ID.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017787b.shtml
Hope this helps. If so, please rate the post.
Brandon
Blue
mgcp does not support callerID due to it does not have the facilities to pass this information.
you'll need to have an h323 gateway configured using those FXO ports if you require callerID.
Hi Abduljaleel,
I'm installing a callmanager with a voice gateway in Dubai, but I'm facing disconnection problems with FXO-v2 ports.
Can you provide me with the custom cptone you are using there?
I appreciate your help.
Georges
Hi Apply this command for voice disconnection
apply this in global config mode
voice class dualtone-detect-params 1
freq-max-deviation 25
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
voice class custom-cptone UAE-CUSTOM-ALCATEL
dualtone disconnect
frequency 425
cadence 375 375
apply below under each voice-port
input gain 14
connection plar opx XXXX
caller-id enable..
revert back if u need ny further assistance
hi Abduljaleel,
it didn't work. I'm still facing the same disconnection problem.
Is there any other disonnect frequency and cadence in Dubai?
Thanks.
I am facing the problem with Fxo disconnect supervision.My customer is having one pstn number number and 10 fxo lines for that single number.
Sometimes the call coming to this number is not getting into the plar number number configured but getting ringback tone to the person who is calling.
Some times its getting ringing on ip phone ,but when try to answer its getting disconnected.
Can you please provide me any working config for FXO port,freq,ring cadence
My customer is in dubai and using etisalat connection
thanks in advance
Abdul,
You have: Analog FXO + MGCP Gateway + CallManager. This is not supported. There is a bug for this. The workaround is to use H.323
Here is a snip from the below doc
'Caller ID does not work on FXO ports. This is because caller ID is not supported with FXO ports when configured for MGCP. Configure the gateway in H.323 mode instead'
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017825e.shtml
Gabriel
285
