07-16-2002 06:35 AM - edited 03-12-2019 07:55 PM
Hi all,
We have 2 callmanagers with centrailized call processing and 4 3640 with T1/PRI connect to telco in four different offices.
I test with T1 PRI last night, it will show my cell phone number on IP Phone, but it wont show Phone number on my cell phone if i call from IP Phone. I ensure that our Telco will send digits.
I enable "Presentation Bit" -->Allowed and "Display IE Delievery" -->click
Aslo I have debug ISDN q931, so u guys can help me out here.
Router#debug isdn q931
ISDN Q931 packets debugging is on
Router#
2d03h: ISDN Se1/0:23: TX -> SETUP pd = 8 callref = 0x0025
2d03h: Bearer Capability i = 0x8090A2
2d03h: Channel ID i = 0xA98397
2d03h: Calling Party Number i = 0x0081, '7522', Plan:Unknown, Type:Unkno
wn
2d03h: Called Party Number i = 0xA1, '19171235467', Plan:ISDN, Type:Nati
onal
2d03h: ISDN Se1/0:23: RX <- CALL_PROC pd = 8 callref = 0x8025
2d03h: ISDN Se1/0:23: RX <- PROGRESS pd = 8 callref = 0x8025
2d03h: Progress Ind i = 0x8288 - In-band info or appropriate now availab
le
2d03h: ISDN Se1/0:23: TX -> DISCONNECT pd = 8 callref = 0x0025
2d03h: Cause i = 0x8090 - Normal call clearing
2d03h: ISDN Se1/0:23: RX <- RELEASE pd = 8 callref = 0x8025
2d03h: ISDN Se1/0:23: TX -> RELEASE_COMP pd = 8 callref = 0x0025
Thanks a millions
Ken
07-16-2002 06:33 PM
Ken,
We had a similar problem. In our case it turned out to be the service provider had not screened our phones for caller ID. Refer to this post for another solution that was provided for us.
Ron
07-19-2002 06:50 AM
Hi Ron,
I follow your instruction, it is work. However, I call my cell, only get 4 digits.
We have 2 callmanager(primary and secondary), use 4 digits dialing plan.
The phone I got from cell phone is the one I assign to IP PHone (DN number).
Also, I use 3640 T1/PRI.
How can I get 10 digits. For example: IP Phone(DN:5000), I want my cell recieve (212 234-5000) something like that.
Is there anyway to accomplish this problem.
Ken
07-19-2002 10:32 AM
You could try and check your route patterns and add the party transform mask there to append the numbers you want. Not sure if this is what you are looking for.
07-19-2002 09:20 AM
"Presentation Bit" is for inbound. If you would like the PSTN user to see the DN from the IP phone you need to code it in the "External Phone Number Mask" on the IP phone's line setting page
07-21-2002 06:01 PM
You can use external phone number mask, but I have found it easier to set the calling party mask on the route pattern or route group. You also have to check with your provider to make sure your numbers are enabled for caller ID. I had a situation where I would hand out the individual DID and get no caller id, when I changed the mask to the main number, it worked fine. Only the main number was enabled for Caller ID.
07-23-2002 12:20 PM
Another approach to get your 10 digit Caller ID sent out would be to set on the gateway the parameter "Caller ID DN" to something like this: 30776XXXXX assuming your using five digit dialing.
