Caller input during opening greeting
<br>Hi,<br><br>I have Unity 3.0.2 with Call Manager 3.1(2c) and I'm trying to setup an outside number that subscribers can call and sign-in to get voice mail.<br><br>I've got a dummy extension in CM forwarding to Unity; my Opening Greeting call handler is setup and caller input is enabled, the default keys "#", "0", and "*" are locked. Pretty mcuh everything is at default settings.<br><br>When I dial into the number I get the greeting, but all of my caller input is ignored and I'm sent to the default action (xfer to operator). I've tried putting extensions in as well, same result.<br><br>I saw an old monkey answer for setting up a Call Routing forward rule from the extension to the Opening Greeting in Unity 2.4.6, and I tried that for the hell of it. Still no go.<br><br>Any ideas?<br><br>Thanks,<br>Mark<br><br>
Anonymous
N/A
Re: Caller input during opening greeting
doesn't sound like a Unity configuration thing, sounds like we're not getting digits from the outside. Do you have the DTMF-relay setup? Checkout this post:
http://avforums.isomedia.com/cgi-bin/showthreaded.pl?Cat=&Board=unityent&Number=7361&Search=true&Forum=All_Forums&Words=dtmf-&Match=Entire Phrase&Searchpage=0&Limit=25&Old=allposts&Main=7360
Jeff Lindborg
Unity Product Architect/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
Anonymous
N/A
Worked like a charm. Thanks
- Mark
122
