Caller Name CID problems
I can't seem to get Caller Name to show up on my Ip phones. I get caller Number though. Using a PRI from a LEC into a VG200 and h323 from the vg200 to the CCM Box.
Here is an example debug voip ccapi inout and a debug isdn q931.
Thanks in advance...
Shows a call coming in from a 6022745340 # to extention 8110. I know this # puts out valid CID name info as I've tested it on other phones. Doesn't seem like it makes it to the gateway or the gateway isn't processing it.
*Apr 3 23:04:13 arizona: ISDN Se1/0:23: RX <- RELEASE_COMP pd = 8 callref = 0x
035F
*Apr 3 23:04:13 arizona: cc_api_icpif: expect factor = 0
*Apr 3 23:04:13 arizona: g113_calculate_impairment (delay=88,
loss=0), Io=0 Iq=0 Idte=0 Idd=0 Ie=0 Itot=0
*Apr 3 23:04:13 arizona: cc_api_call_disconnect_done(vdbPtr=0x81107AA4, callID=
0x5EE6, disp=0, tag=0x0)
*Apr 3 23:04:13 arizona: sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(2429
4), disp(0)
*Apr 3 23:04:13 arizona: cid(24294)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCO
NNECT_DONE)
oldst(SSA_CS_ALERT_RCVD)cfid(-1)csize(1)in(0)fDest(0)
*Apr 3 23:04:13 arizona: ssaDisconnectDone
*Apr 3 23:04:26 arizona: ISDN Se1/0:23: RX <- SETUP pd = 8 callref = 0x151D
*Apr 3 23:04:26 arizona: Bearer Capability i = 0x8090A2
*Apr 3 23:04:26 arizona: Channel ID i = 0xA98382
*Apr 3 23:04:26 arizona: Calling Party Number i = 0x21, 0x83, '60227453
40', Plan:ISDN, Type:National
*Apr 3 23:04:26 arizona: Called Party Number i = 0xC1, '8110', Plan:ISD
N, Type:Subscriber(local)
*Apr 3 23:04:26 arizona: cc_api_call_setup_ind (vdbPtr=0x8137D86C, callInfo={ca
lled=8110,called_oct3=0xC1,calling=6022745340,calling_oct3=0x21,calling_oct3a=0x
83,calling_xlated=false,subscriber_type_str=RegularLine,fdest=1,peer_tag=10, pro
g_ind=0},callID=0x81532040)
Re: Caller Name CID problems
If the name for a given call was truly being sent, you'd see it in the q931 debug. In this particular call, it's not, so test with a different inbound call from a phone that *is* sending their name.
As for Call Manager config, on your h.323 gateway config page, make sure the checkbox for "Display IE Delivery" is checked.
could someone send me an example of an isdn q931 debug showing the right calling name/number? I'm about to set one up and I would like to have a look at one.
Thanks. jalvarado@ccs.hn
This feature Call Name Display single this available one with interfaces E1 PRI QSIG. It is this your case?
I have made tests with many types of interface E1 PRI, and now I am looking for if a version of CCM exists that has supported E1 QSIG.
I wait for your answer.
99
