Caller Name problem with outbound calls
I am implementing Caller Name on a 1760V. I can turn on this feature on the serial interface using the "isdn supp-service name calling" command and for inbound calls it works great, the name appears on the PBX and on the desktop phone. The problem is that outbound calls do not go through. The gateway logs a message "Cause i = 0x82B2 - Requested facility not subscribed" (see log snippet below). I assume that is because the gateway is trying to set the Calling Party Name on the outbound call and the PSTN provider is rejecting that. Can anyone verify that from the log below? Can I tell the gateway not to forward the Calling Party Name? Would the "calling-info sip-to-pstn unscreened discard" command under sip-ua help?
Log Snippet:
*Dec 7 02:37:31.599: ISDN Se0/0:23 PACKET: handle_mail: received:
dest_id = 0, source_id = 512, prim = 141
priv_ln = 4, int_id = -2095139576, datasize = 20
*Dec 7 02:37:31.599: ISDN Se0/0:23 PACKET: L2IF_DispPak: packet - start(5784338), size (20) 0x00010126313A2055736572205458202D
*Dec 7 02:37:31.599: 3E20494E
*Dec 7 02:37:31.599: ISDN Se0/0:23 PACKET: handle_mail: received data = 0x00010126
*Dec 7 02:37:31.607: ISDN Q921d: isdn_from_driver_process: QUEUE_EVENT
*Dec 7 02:37:31.607: ISDN Se0/0:23 Q921f: User RX <- 0x020176260802D4F25A080282B2
*Dec 7 02:37:31.607: ISDN Se0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=59 nr=19
*Dec 7 02:37:31.607: ISDN Se0/0:23 Q931: RELEASE_COMP pd = 8 callref = 0xD4F2
Current configuration : 1895 bytes
version 12.3
hostname GW
boot-start-marker
boot-end-marker
enable secret 5 $1 omitted
tdm clock T1 0/0 both export line
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
voice-card 0
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
isdn switch-type primary-ni
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
modem passthrough nse payload-type 103 codec g711ulaw
sip
controller T1 0/0
framing esf
linecode b8zs
pri-group timeslots 1-16,24
translation-rule 100
Rule 1 658 15083668503
interface FastEthernet0/0
ip address 192.168.168.5 255.255.255.0
speed auto
interface Serial0/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.168.168
no ip http server
control-plane
voice-port 0/0:23
translate called 100
dial-peer voice 1760 voip
application session
destination-pattern 3..
session protocol sipv2
session transport udp
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 100 pots
description Incoming Sip calls sent to PRI
application session
destination-pattern T
direct-inward-dial
port 0/0:23
dial-peer voice 101 pots
application session
destination-pattern .T
direct-inward-dial
port 0/0:23
forward-digits all
dial-peer voice 1761 voip
application session
destination-pattern 5..
dtmf-relay rtp-nte
codec g711ulaw
line con 0
line aux 0
line vty 0 4
1 REPLY
Re: Caller Name problem with outbound calls
Anyone have any thoughts on this? I want to tell the gateway to not pass Caller Name on outbound calls.
223
