Community Member
caller number doesn't appear
i have a CALLMANAGER 4.1(2)and 1760 cisco router with 2 4-ports fxo modules. when an external call comes the caller number doesn't appear on the IP phone screen although the telephone lines have this feature enabled and caller number appears when connecting these lines directly to an analog telephone set. but this works well with internal calls. so please let me know if any configuration is needed on the callmanager or on the router.
your aid is highly appreciated
Hall of Fame Super Silver
Re: caller number doesn't appear
What protocol do you use to control these GWs?
MGCP does not support Caller ID with FXO lines, so make sure you configure them as H.323!
HTH, please rate all posts!
Chris
Community Member
you are right, the protocol used is MGCP but it's not optional to make change it to H323.
on the callmanager when i specify the router type as 1760 the protocol is automatically choosen as MGCP.
so please are there any thing else that i can do?
i attached to you the router complete configuration hoping to help
thanks for ur help
TO configure H.323 GW in CCM you cannot use the router model, but instead use H323 Gateway option from the drop down menu, there you either specify the DNS name or IP address.
On the GW itself you will need to create dial-peers to point to CCM and to the pots lines, for example lets say you have an FXO card in slot 1/0, then your config would look like this:
dial-peer voice 1 pots
connection plar opx 2000
destination-pattern 911
port 1/0
forward digits all
dial-peer voice 2 pots
destination-pattern 9[2-9]......
port 1/0
forward digits 7
dial-peer voice 3 pots
destination-pattern 91[2-9]..[2-9]......
port 1/0
forward digits 11
dial-peer voice 4 pots
destination-pattern 9011T
port 1/0
prefix 011
dial-peer voice 10 voip
session-target ipv4: 10.1.1.1
destination-pattern 2000
no vad
dtmf-relay h245-alphanumeric
Chris
123
