CallerID will not display using MGCP
We have upgraded a gateway to MGCP from H.323 and the outgoing calls no longer displayed the called party digits. We were also experiencing one-way voice which may have caused this.
Are there any other reasons why this may occur?
Thank you,
Erik.
Re: CallerID will not display using MGCP
Is this by any chance an FXO gateway?
Well, we do have a link to a PABX...
controller E1 0/0
pri-group timeslots 1-31
description QSIG PRI to MD110 Clock from PABX clocks Router
controller E1 0/1
shutdown
controller E1 0/2
shutdown
interface Loopback0
ip address 172.1.1.1 255.255.255.255
interface FastEthernet0/0
description Connection to Main HQ Enterasys switch
ip address 1.1.5.5 255.255.255.0
load-interval 120
speed 100
full-duplex
h323-gateway voip interface
h323-gateway voip bind srcaddr 1.1.5.5
interface Serial0/0:15
no ip address
no logging event link-status
isdn switch-type primary-qsig
isdn overlap-receiving
isdn protocol-emulate network
isdn incoming-voice modem
isdn T203 30000
isdn T310 60000
isdn bchan-number-order ascending
no cdp enable
That doesn't look like MGCP is configured. Here is what MGCP for CallManager looks like:
mgcp
mgcp call-agent 10.1.1.2 2427 service-type mgcp version 0.1
ccm-manager mgcp
ccm-manager music-on-hold
controller E1 1/0
pri-group timeslots 1-31 service mgcp
interface Serial1/0:15
no ip address
isdn incoming-voice voice
isdn T310 4000
isdn bind-l3 ccm-manager
no cdp enable
dial-peer voice 9991015 pots
application mgcpapp
port 1/0:15
In CallManager you should have an MGCP gateway configured of the proper IOS gateway type, the name for it should be the name exactly as it appears on the router.
Things should sync up then. One warning, IOS QSIG and CallManager QSIG aren't 100% the same, so you may get some odd results.
I should add that if you're just doing IOS gateway to IOS gateway, H.323 is the only supported method unless CallManager is controlling both gateways.
102
