Callmanager 3.3(3) Upgrade from 3.3(2) Require OS reload?
During a Callmanager to 3.3(3) Upgrade from 3.3(2) on a system that already has OS 2.4 do you still need to wipe the system and reload from scratchw with 2.4? Or can you just run the callmanager upgrade?
Bronze
Re: Callmanager 3.3(3) Upgrade from 3.3(2) Require OS reload?
No, you dont need to wipe clean, once you are on 2.4 you are good to go.
This hasn't been released yet has it?
Bronze
No, but its right around the corner. Hopefully sometime in the next 2 weeks.
Dang, does that mean 3.3(3) will require OS 2.4? I am running 3.3(2)spC with OS 2.3. If it does require OS 2.4, then is that a wipe-n-load again?
Tom.
Im in the same boat. It looks like there is an upgrade from 2.3 that will take you to 2.4. So Can we assume this will work? Otherwise it would be a waste of time to upgrade to 2.4
Bronze
Yes, the web upgrade will work as long as the server was imaged with 2000-2-3 or greater CD's.
Bronze
You wont have to wipe and reload, but you may have to run the web downloadable 2000-2-4 upgrade.
97
