CallManager 3.3 using Gatekeepers
Hello. I honing my h323 skills here in prep for the voice lab. Anyway, I have a network with Core and Remote 2651xm routers (back to back t1 via WIC-1DSU cards) and a 2621 as a gatekeeper at each site. CCM is at the "core" site. Can someone post a config for the gatekeeper, and POTS 2651xm routers as well as discuss the necessary configs in CCM administration. I believe you gotta configure a "Gatekeeper", then a trunk, then route pattern pointing to that trunk, correct?
Anyway, I am plowing through this and just thought someone may be an expert at this already. Thanks in advance for the assistance.
-Ron
1 REPLY
Silver
Re: CallManager 3.3 using Gatekeepers
Does your remote site fall within the CallManager cluster at Core site. If so, you cannot use Gatekeepeer in this scenario. For CAC, you have to use locations. If the remote site is a separate CCM cluster by itself, or is using CallManager Express, then you can proceed with the config I am posting. Here my remote site has CCME, and Core site has publisher and subscriber.
Gatekeeper Config:-
gatekeeper
zone local core cisco.com 192.168.40.254
zone local remote cisco.com
zone prefix remote 4* gw-priority 10 192.168.63.254
zone prefix core 3* gw-priority 10 192.168.60.11
zone prefix core 3* gw-priority 9 192.168.60.10
gw-type-prefix 1#* default-technology
arq reject-unknown-prefix
bandwidth interzone zone core 32
bandwidth interzone zone remote 32
no shutdown
Remote with CCME:-
interface FastEthernet0/0.63
description Interface for CME IP Phones
encapsulation dot1Q 63
ip address 192.168.63.254 255.255.255.0
h323-gateway voip interface
h323-gateway voip id remote ipaddr 192.168.40.254 1718
h323-gateway voip h323-id cme
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 192.168.63.254
In Core CallManager:-
Your configuration steps were correct. Configure the trunk as a h225 Trunk.
Partha
83
