User will get queue prompt when all lines/users in AC hunt group are busy.
Queue prompt for AC pilot it is a MoH Audio Source file. To define it do the following:
1. Create additional Device Pool for your AC Pilot.
2. Add your queue promtp in CCM as a additional MoH Audio Source file.
3. In Device Pool configuration in User/Network MoH Audio Source specify this queue prompt.
4. In AC config tool you only should enable queueing.
5. Device Pool must have MoH resources available.
I did it in my CCM configuration and it works without any problems...
Wojtek
