Silver
CallManager 4.1(3) ES 66 - CDR, IVR and CTI Port, record not being created
Just after quick confirmation if possible.
If a call comes in and gets queued on an IP IVR, then the IVR fails to deliver the call to an agent.
Should we see a record created in CDR?
Cheers,
Tim.
Green
Re: CallManager 4.1(3) ES 66 - CDR, IVR and CTI Port, record not
Yes, all calls will be recorded, you can check them in the EnvProcessCDR function under CCM.exe.
It should give u a reason.
Silver
Cheers for that.
Did some more digging. Looks like one particular callmanager (a sub) is not creating any CDR records. (i.e. not even creating the flat files)
There are some interesting DB Layer Monitor Service logs. But can you confirm - is the CallManager service the actual service that is responsible for creating the initial flat file?
How do we check the EnvProcessCDR?
Cheers,
Tim.
189
