CallManager 4.1 and WiFi phones like Nokia
Does CallManager support WiFi GSM phones?
Or it is used only in CCM 5?
Hall of Fame Super Red
Re: CallManager 4.1 and WiFi phones like Nokia
Hi Alexandr,
The Nokia E Series is supported with CCM 4.x versions as well. The support docs and software can be found here;
http://www.businesssoftware.nokia.com/nokia_intellisync_call_connect_for_cisco_downloads.php
Hope this helps!
Rob
Does Nokia phones use SCCP or SIP?
Do I need something on CALLMANAGER?
Or only installation of this software help me to register Nokia phones on CCM?
Hi Alexandr,
The Nokia phones support SCCP and SIP, but the current model with CCM only supports SCCP.
My understanding is that installing the Nokia Call Connect software adds the S60 (Nokia) to the Device Defaults on CCM;
Adding Device Types to Cisco Unified Communications Manager 4.x
A Windows installation program that adds support for the Nokia S60 device
type to Cisco Unified Communications Manager 4.x is available on the
following Nokia Web sites:
􀂄 Nokia Support-https://support.nokia.com/
􀂄 Nokia Business Software-http://www.businesssoftware.nokia.com/
bc_product.php?pid=1621&cid=001000000000000000f0&f=0
Hope this helps!
Rob
347
