Silver
CallManager 4.2 MGCP Partial E1 PRI then H323 in SRST mode!
Hi Guys,
I know MGCP and partial E1's are not supported. I have ISDN 10 channel PRI's running into about 4 sites.
There was a workaround posted on netpro involving changing service parameters to put the last 20 channels out of service.
This seems to work quite well. ccm-manager config server command works fine etc.
I am turning on SRST now, though and the H323 dial peers outbound think my E1 is a 30 channel and want to send calls out channels that dont exist.
Any ideas, or better ways to do this?
Or even better does anyone know when a partial E1 will be supported under MGCP? Our local SE at Cisco says it is not on the road map at all.
Perth is quite small and has lots of partial E1's :)
Cheers,
Tim
347
