CallManager 4;X : PBX Interoperability Tenovis (Bosh) with E1 QSIG
Is it possible to connect a Tenovis (Bosh)PBX via a QSIG PRI or IP H323 to a 2800 series router.An experience about that?
Thanks a lot
Cedric
1 REPLY
Bronze
Re: CallManager 4;X : PBX Interoperability Tenovis (Bosh) with E
It looks as though the Tenovis I55 supports both QSIG and H.323; this would make it fairly straight forward to connect to CCM, we have not performed any formal testing on it.
In terms of IOS, I would recommend that you use a mainline IOS such as 12.2(10b) or greater. Usually the higher IOS's are more stable.
337
