Bronze
Callmanager 5.0(4) and NIC redundancy
I am currently installing a two callmanager cluster running 5.0(4).Everything works fine apart from the dual nic config.
I have used the set network failover ena command and both nics flash on the front of the server and the switches report that the link is up.
However when i go into OS admin the callmanager thinks that one of the NICs is down.
Anyone seen anything like this.
cheers
mark
Bronze
Re: Callmanager 5.0(4) and NIC redundancy
Can you try swapping the NIC and see if it is working properly
What type of server is it. Cisco dont support NIC teaming on IBM platforms. It is supportd only on HP platforms.
Jay
115
