CallManager and 2600 PRI via h.323
Does anyone have a sample configuration to share for a 2620 router used as a PRI gateway to CCM 3.0(8)?
1 REPLY
Re: CallManager and 2600 PRI via h.323
Here is a 3600 with PRI configured as H.323 gateway....enjoy
3640-GSX-R1#show run
Building configuration...
Current configuration:
version 12.1
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname 3640-GSX-R1
enable secret 5 $1$Tpeu$BBOAknyjPOkTCZB00sOsD.
voice-card 2
ip subnet-zero
ip tcp synwait-time 5
no ip domain-lookup
isdn switch-type primary-5ess
isdn voice-call-failure 0
call rsvp-sync
voice rtp send-recv
voice service pots
controller T1 2/0
framing esf
linecode b8zs
pri-group timeslots 1-24
controller T1 2/1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation isl 10
ip address 172.16.1.251 255.255.255.0
no ip redirects
interface FastEthernet0/0.2
encapsulation isl 20
ip address 172.16.56.251 255.255.255.0
ip helper-address 172.16.1.11
no ip redirects
interface Serial2/0:23
no ip address
no logging event link-status
isdn incoming-voice voice
no cdp enable
router eigrp 1
network 172.16.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.1.250
no ip http server
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
voice-port 2/0:23
input gain 6
output attenuation 6
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 9T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 2/0:23
dial-peer voice 2 voip
destination-pattern 6302...
progress_ind setup enable 3
session target ipv4:172.16.56.2
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 3 voip
destination-pattern 6303...
codec g711ulaw
dial-peer voice 4 voip
destination-pattern 6304...
codec g711ulaw
dial-peer voice 5 pots
destination-pattern 9011T
port 2/0:23
dial-peer voice 100 pots
dial-peer voice 200 voip
gateway
line con 0
exec-timeout 0 0
logging synchronous
transport input none
line aux 0
modem InOut
modem autoconfigure discovery
speed 1200
flowcontrol hardware
line vty 0 4
password 7 10405B171303
login
end
116
