02-15-2006 09:00 AM - edited 03-13-2019 12:10 PM
Hi all,
i've configured my callmanager with AD integration, so now from the callmanager administration page under "users --> global directory" i can see the users configured on the active directory server.
But i've a question, is it possible to create users from callmanager administration page? or i can only add new users from the AD server?
Claudio.
02-15-2006 09:46 AM
Claudio,
Yes, you can add users through CCM admin. You will need to update the registry key referenced in the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094493.shtml#topic3
Hope this helps. If so, please rate the post.
Brandon
02-16-2006 01:30 AM
Thanks Brandon, i'll try it asap.
Cheers,
Claudio.
02-20-2006 01:54 PM
Just curious if this ended up solving your problem.
Brandon
02-21-2006 03:24 AM
Yes Brandon,
this solution solves the problem.
Thanks again.
02-21-2006 06:49 AM
If it helped, would you mind to rate the post?
Brandon
02-22-2006 09:19 AM
rated :-)
Thanks.
