CallManager and AD Integration
vectraeee
Hi all,
i've configured my callmanager with AD integration, so now from the callmanager administration page under "users --> global directory" i can see the users configured on the active directory server.
But i've a question, is it possible to create users from callmanager administration page? or i can only add new users from the AD server?
Claudio.
6 Replies 6
Brandon Buffin
Claudio,
Yes, you can add users through CCM admin. You will need to update the registry key referenced in the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094493.shtml#topic3
Hope this helps. If so, please rate the post.
Brandon
Thanks Brandon, i'll try it asap.
Cheers,
Claudio.
Just curious if this ended up solving your problem.
Brandon
Yes Brandon,
this solution solves the problem.
Thanks again.
If it helped, would you mind to rate the post?
Brandon
rated :-)
Thanks.
