Community Member
callmanager and phone integration steps
Dear Pros,
Please help me to solve the following
1. How to integrade callmanager 4.1(3) running on MCS 7825 and IP Phone 7912G and the steps . I tried to confgiure the callmanager admin tools but the phone is not registerd.I do not know the proper steps to be followed. I have no previous hands on.
2. I wants to configure the voice gateway with 4 port FAX module. Could you provide me the config to do so.
3.I need to add FAX machines to all the buildings in the campus. How can i do it with out the router in each building.Is it ok to use ATA18X.
Please waiting your reply
Re: callmanager and phone integration steps
writing out all the steps you require will be very lengthy and may just prove to confuse you. so i'll post the best 'examples and configuration notes links' for your requests.
as far as the configuration for 4 FAX lines with an FXS module, again, configuration can very depending on your IOS version and features required.
see this link for step-by-step FXS configuration:
yes, you can use an ATA18x for a FAX connection to your CCM environment.
see this link for step-by-step ATA configuration:
to configure an IP Phone (7912G) to register to CCM see this link for step-by-step configuration:
