CallManager Attendant Console over WAN connection
smh1218
Does anyone know if it is possible to run Attendant Console over the WAN. I have a branch office that I would like to install AC, but I cannot seem to get the Call Control layer up when I start the AC gui.
Any suggestions?
gogasca
Level 10
Level 10
The use of the Attendant Console outside of the central site can require a considerable amount of bandwidth if the remote sites must access large user account directories without caching them.
-Apart from IP Phone requirements , AC needs Jtapi messages communications
-Line State Updates..It depends on number of phones which change line state at a given time ..TCD server sends this as UDP packets..And how many of these are listed on the console directory/speed dial at a given
time..
Say we have 10 phones getting a new call at a time and for of these are listed on Console , we will get line state for 4 phones.
-At each login , the console connects to server and checks if userlist file has changed and if changed it downloads the same..Workaround is to have local copy of this file
But this is usually a one time step per login session.
Regarding your question, it should work, verify that no ACLs, FW or other network device is blocking traffic from|to CCM and AC console|IP Phone.
You may check this link to verify configuration is fine.
AC user password (12345)
PP|IP Phones associations
CTI|TCD started
etc
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_0/sys_ad/4_0_1/ccmcfg/b04ccmac.htm
gogasca
Level 10
Level 10
time..
CTI|TCD started
etc
