CallManager Backups and restoring after upgrade
Looking to upgrade from 3.2.2c to 3.3.3. In demoing the upgrade on some lab servers, I tried to restore the data from the 3.2 server on the newly built 3.3 server. I got the message from the back up system that " The callmanager archive appears to be version 3.2(2C), whereas the installed callmanager version installed is 3.3(3x). You may need to install callmanager version 3.2(2C) in order to restore this data."
Well, obviously, I don't want to reinstall an older version so how can i get the production data on the new systems?
I also noticed that on my 3.2 system, when i do a manual back up to a local directory, I do not have the files dbname.ini and backup.ini! whats up with that??
Bronze
Re: CallManager Backups and restoring after upgrade
I had similiar issues, follow the link that best suits your enviornment. Follow them exactley, trully it makes a difference! :)
Replacing the server during Call Manager 3.3 upgrade.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_3/install/upgrade/hwupg33.htm
These are the instructions for 3.3.3 upgrade.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_3/install/upgrade/upgra333.htm
Geoff
Thats great help Geoff, thanks.
I still need to know why my production server does not have a recover directory and I cannot find the dbname.ini and backup.ini files.
Bronze
do you have backup version 3.5.X or higher? The older versions did not create the folder you are asking about. That is in the documents as well.
Geoff
Thanks again, Geoff.
107
