10-31-2007 03:34 PM - edited 03-13-2019 04:39 PM
I have an FXO card and a line from PBX connects to this port.
When an analog line calls the IP Phone extensions and hangs up the IP phone continues to ring????
i have configured disconnect options, however, symptoms are still the same
10-31-2007 04:23 PM
Which exact IOS are using ?
Is this with OPX configured in "connection plar' ?
Disconnect is an issue however it must be not up to the phone that phones keeps ringing forever.
10-31-2007 04:48 PM
not sure why the low rating. The two questions I asked above are the first to answer to work on the problem, if you expected magic in resolving your problem, that doesn't work with routers sorry.
10-31-2007 04:51 PM
accidental rating, drop down box took the wrong rating - internet problems here....
10-31-2007 04:49 PM
IOS - 12.4(13r)T
i am currently using - Connection plar 3600
10-31-2007 04:53 PM
Ok, without disconnect supervision working you definitely need to configure OPX in as option in 'connection plar".
Not to insist on the rating issue, but the proper 'etiquette' would be to wait until issue is either solved or not before expressing a rating.
10-31-2007 04:55 PM
ok, i'll try and get back to you
10-31-2007 05:06 PM
Sure.
With connection plar OPX you are OK even with non-functional disconnect supervision, as long you are not using automated services (AA and the like) on the router. But for basic person-to-person calls it will be fine.
