Callmanager Express-Phones don't ring but show incoming call
I am having a wierd problem with Call Manager Express. The 7940 shows and incoming call on the display, but the phone doesn't actually ring, or, if it does it will ring on the 4th or 5th ring that the caller hears. Any ideas?
thanks,
Aaron
Re: Callmanager Express-Phones don't ring but show incoming call
Sorry I don't have an answer for you, Aaron. I just wanted to weigh in that I have the same issue on a 7960 phone with a 7914. If I get a resolution for this I will let you know. - Jerry
Silver
Can you post your config? I had a similar problem when I didn't set up an "app" properly. Do you get dialtone (or eventually?)
Also play with the firmware version, but less likely a problem.
And of course, what version of CCME (ITS)
Silver
Did you get a solution to this? If not, please post your config !!
I never saw these posts! Here is the config. Thanks for the help in advance. It seems to work when I reboot the 3640 every so often, but after a while the phones will start to tweak if the router isn't rebooted. Memory leak?
Here's the config-
3640-pbx#sh run
Building configuration...
Current configuration : 5956 bytes
! Last configuration change at 03:31:59 PST Fri Dec 26 2003
! NVRAM config last updated at 23:22:17 PST Tue Dec 30 2003
version 12.2
hostname 3640-pbx
logging queue-limit 100
logging buffered 51200 warnings
clock timezone PST -8
clock summer-time PDT recurring
ip subnet-zero
ip cef
ip multicast-routing
ip audit notify log
ip audit po max-events 100
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
class-map match-all voice
match access-group 105
policy-map VOIP
class voice
priority percent 60
class class-default
fair-queue
interface FastEthernet3/0
ip address 10.1.1.8 255.255.255.0
ip pim sparse-dense-mode
service-policy output VOIP
duplex auto
speed auto
ip http server
no ip http secure-server
ip http path flash:
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.1.1
logging trap warnings
logging 10.1.1.2
access-list 20 permit 10.1.1.2
access-list 105 permit ip any any dscp ef
access-list 105 permit udp any any range 16384 32767
access-list 105 permit ip any any precedence critical
access-list 105 permit ip any any tos 5
access-list 105 permit gre any any
tftp-server flash:P00403020214.bin
tftp-server flash:P00303020214.bin
snmp-server community n0t0nyrlf RO 20
snmp-server enable traps tty
call rsvp-sync
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/1/0
connection plar 200
description 8314233282
voice-port 0/1/1
connection plar 200
description 8314237407
voice-port 2/0/0
voice-port 2/0/1
mgcp profile default
dial-peer cor custom
dial-peer voice 10 pots
destination-pattern 9...........
port 0/1/0
dial-peer voice 12 pots
port 0/1/1
dial-peer voice 11 pots
destination-pattern 9[2-9]......
port 0/1/0
dial-peer voice 13 pots
port 0/1/1
telephony-service
load 7910 P00403020214
load 7960-7940 P00303020214
max-ephones 40
max-dn 100
ip source-address 10.1.1.8 port 2000
system message Welcome to xxxxxxxxxxx
url services http://xxxxxxxxx
create cnf-files version-stamp 7960 Jun 05 2003 04:15:23
voicemail 9001
mwi sip-server 10.1.1.8 transport tcp
mwi expires 86400
max-conferences 4
moh music-on-hold.au
web admin system name xxxxx
dn-webedit
time-webedit
directory last-name-first
ephone-dn 1
number 104
name xxxxxxxxx
call-forward busy 9001
call-forward noan 9001 timeout 40
mwi sip
hold-alert 30 originator
ephone-dn 2
number 101
name xxxxxxxxx
mwi sip
ephone-dn 3
number 102
name xxxxxxxx
mwi sip
ephone-dn 4
number 106
name xxxxxxxxx
mwi sip
ephone-dn 5
number 108
name xxxxxxxxxx
mwi sip
ephone-dn 6
number 200
name xxxxxxxxxxx
mwi sip
ephone-dn 7
number 300
name Page
paging ip 225.0.1.20 port 2000
ephone-dn 8
number 103
name xxxxxxxx
mwi sip
ephone-dn 9
number 105
name xxxxxxx
mwi sip
ephone-dn 10
number 202
name xxxxxxxxxxx
mwi sip
ephone-dn 12
number 113
name xxxxxxxxxxx
mwi sip
ephone-dn 13
number 100
name xxxxxxxxxxxx
mwi sip
ephone-dn 14
number 201
name xxxxxxxxxx
mwi sip
ephone-dn 80
number 8000 secondary 8001
mwi on-off
ephone-dn 90
number 9001
name Voice Mail
no huntstop
ephone 1
mac-address 000B.BEB2.623B
paging-dn 10
type 7960
button 1:8 2:1 4f2 5:3 6:6
ephone 2
vm-device-id CiscoUM1-VI1
button 1:90
ephone 3
vm-device-id CiscoUM1-VI2
ephone 4
mac-address 000A.F44F.EEAF
paging-dn 10
type 7940
button 1:4 2:2
ephone 5
mac-address 0007.5079.D2B6
paging-dn 10
type 7940
button 1:6 2:14
ephone 6
mac-address 000B.FDB8.187F
paging-dn 10
type 7940
button 1:12 2:2
ephone 7
username "7910" password 7910
mac-address 000A.F44F.F5AC
paging-dn 10
type 7910
button 1:2 2:3
ephone 8
mac-address 0030.94C2.E94D
type 7960
button 1:10 5:2 6:3
ephone 9
mac-address 000B.FD04.2AE1
type 7940
button 1:9 2:2
line con 0
line aux 0
line vty 0 4
login
transport input telnet ssh
ntp clock-period 17179902
ntp server 207.46.130.100
ntp server 207.46.248.43
end
3640-pbx# sh ver
IOS (tm) 3600 Software (C3640-IK9O3S-M), Version 12.2(15)ZJ, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 22-May-03 08:34 by pwade
Image text-base: 0x60008950, data-base: 0x61E92000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3640-IK9O3S-M), Version 12.2(15)ZJ, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
3640-pbx uptime is 1 week, 9 hours, 0 minutes
System restarted at 14:55:19 PST Tue Dec 23 2003
System image file is "flash:c3640-ik9o3s-mz.122-15.ZJ.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 3640 (R4700) processor (revision 0x00) with 94208K/4096K bytes of memory.
Processor board ID 17147016
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
1 FastEthernet/IEEE 802.3 interface(s)
4 Voice FXO interface(s)
2 Voice FXS interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
3640-pbx#
1 20764064 c3640-ik9o3s-mz.122-15.ZJ.bin
2 333822 P00403020214.bin
3 369950 P00303020214.bin
4 3743 admin_user.html
5 559026 admin_user.js
8 16948 dom.js
10 6315 ephone_admin.html
12 3603 normal_user.html
13 77638 normal_user.js
17 2326 telephony_service.html
19 10230 xml-test.html
20 496521 music-on-hold.au
21 2515 xml.template
23 721 speeddial.xml [deleted]
24 764 speeddial.xml [deleted]
25 765 speeddial.xml
26 3114 logo.xml
27 364544 satoshi.au [deleted]
28 4270199 satoshi.au
29 2290688 sdm.tar
30 14617 sdm.shtml
214
