CallManager Express TCL Script issue
Hi, I'm having issues trying to get an AA script working on a CME 4.0 system. What I want to do is quite simple, i just want to play a message to callers and that's it.
When I dial the pilot, the call just drops and I get the following error when debugging "voip application script"
Jul 25 17:16:22.470: //381//TCL :/tcl_PutsObjCmd: TCL AA: +++ B-ACD-SERVICE not registered, Starting B-ACD-SERVICE +++
Jul 25 17:16:22.470: //381//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tcl modulespace. code=1 code=ERROR
Jul 25 17:16:22.470: TCL script failure
Result:
Handoff Failed
Jul 25 17:16:22.470: TCL script failure errorInfo:
Handoff Failed
while executing
"handoff appl leg_incoming $serviceName -s $hString"
(procedure "act_Setup" line 30)
invoked from within
"act_Setup"
(procedure "act_Handoff_Activity" line 7)
invoked from within
Below is my config
application
service aa flash:app-b-acd-aa-2.1.0.0.tcl
paramspace english index 1
param number-of-hunt-grps 1
param handoff-string aa
paramspace english language en
param max-time-vm-retry 3
param aa-pilot 1050
paramspace english location flash:
param second-greeting-time 60
param welcome-prompt _bacd_welcome.au
param queue-manager-debugs 1
param call-retry-timer 15
param max-time-call-retry 200
param voice-mail 8000
param service-name aa
dial-peer voice 1050 voip
service aa
destination-pattern 1050
session target ipv4:172.27.27.10
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
telephony-service
load 7914 S00104000100
load ATA ATA030100SCCP040211A
load 7920 cmterm_7920.4.0-02-00
load 7971 TERM70.6-0-3SR1S
load 7970 TERM70.6-0-3SR1S
load 7912 CP7912080001SCCP051117A
max-ephones 240
max-dn 480
ip source-address 172.27.27.10 port 2000
timeouts interdigit 5
system message Galaxia - VSAT Activated
sdspfarm units 1
sdspfarm transcode sessions 2
sdspfarm tag 1 mtp0018185bf860
cnf-file perphone
network-locale IT
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-park system redirect
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.x.1.30 port 2123
web admin system name admin password btin3t
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Jul 25 2006 14:09:58
We do not have CUE.
Glyn
Re: CallManager Express TCL Script issue
In reference to this part of your config:
If you are using a hunt group, you need the following param:
param aa-hunt1
I would also try using a loopback addres in your voip dial peer, rather than the H.323 physical IP addres of your router.
here is the link with an example config:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00805f2305.html#wp1012136
Also, if you are using FXO ports, there is a known issue in TAC Case collection that I found. It states that there are inbound connection issues when using the TCL script with SRST mode. This may be an issue, because, as you know, SRST is VERY similar in nature to CME. They are esentially an identical IOS feature set. Here is the link:
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K19651580
Glyn,
Did you resolve your issue? I am getting the same error?
Your configuration doesnt have the queue script. Check this link for proper configurations.
http://www.cisco.com/univercd/cc/td/doc/product/voice/its/cme33/bacd/33bacd.htm#wp1003143
Sankar
PS: please remember to rate posts!
Sorry, should have updated this post. Sankar is correct. Once I had configured the queue side of things, it all started working.
Glyn
194
