Callmanager install problem
After hardware detection CallManager disk is inserted, CallManager shows the first installation windows for ever.
Somebody knows why?
Re: Callmanager install problem
If you are using Call Manager 3.3, then Disk 3 for the MCS7825/35 or Compaq DL320/380 is a DVD. If you only have a CD Drive in your server, it will always sit at the "Enter OS Disk 3" Screen forever.
HTH.
Bill
Bill
Is the first window, there is no user input.
The windows says:
"Cisco Avvid
Architecture for voice, data, etc."
Alex
Hi Alex,
If you have a DL320G2/MCS7825H (2.26Ghz) or DL380G3/MCS7835H, then use need the Hardware Detection disk/OS Disks version 2000.2.4 Earlier CM 3.3(2) Upgrade sets came with 2000.2.3 OS/Harware detection disks. I had this problem with a DL320G2 and 2000.2.3 Disks with the server just hanging at the splash screen. 2.4 Disks work fine.
HTH.
Bill
HI,
So in case a customer just has a set of 2000.2.3 cd's he has to buy another callmanager set of cisco in order to get the 2000.2.4 cd's ?
Is there really no other way ? Any BIOS upgrade or anyhthing ?
Xavier
Make sure you have the server's ethernet plugged into a switch, hub or router and that you have link integrity. The CCM software will not load if not connected to the network.
Jason
Are you doing a fresh installation or recovery?
Also please let us know the call manager version that you are using.
Seetharaman.
124
