Silver
CallManager Transient Connection Attempt
I restarted the Call Manager, and it came up with these errors in the CCM Event Viewer. No problem was noticed with devices, but when tried to start Unity (was shutdown previously), the Unity ports won't get registered, and I got TapiLine Initialization failed errors in the Unity Event Viewer. After trying for about 15mins, Unity started.
Does these errors below has anything to do with this behaviour? I see no other errors in CCM EventViewer.
4/25/2002 9:07:38 PM Cisco Tftp Error None 3 N/A CM001 The description for Event ID ( 3 ) in Source ( Cisco Tftp ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: kCTFTPConnectSendFileNonTimeoutError - NonTimeout error during call to recvfrom().
ErrorNumber: 10054
Block: 1
App ID: Cisco Tftp
Cluster ID: CM001-Cluster
Node ID: 192.168.4.241
Explanation: NonTimeout error occurred during call to recvfrom().
Recommended Action: Ensure your system is connected to the network. Check windows Taskmanager to make sure TFTP is getting sufficient processor
time to serve files. Make sure you are following configuration guide recommendations for your system configuration..
4/25/2002 9:07:37 PM Cisco CallManager Error None 3 N/A CM001 The description for Event ID ( 3 ) in Source ( Cisco CallManager ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: DChannelOOS - D channel out of service.
Device Name.: S0/DS1-0@SDA00908F0034DB
Device IP address: 192.168.4.240
Channel Id.: 24
Unique channel Id: S0/DS1-0@SDA00908F0034DB:24
Reason [Optional].: 0
App ID: Cisco CallManager
Explanation: Indicated D channel has gone out of service.
Recommended Action: Contact TAC for help if this alarm continue to generate..
4/25/2002 9:07:24 PM Cisco CallManager Error None 3 N/A CM001 The description for Event ID ( 3 ) in Source ( Cisco CallManager ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: DeviceTransientConnection - Transient connection attempt.
Connecting Port: 2000
Device name [Optional].:
Device IP address.: 192.168.2.32
Device type. [Optional]: 255
Reason Code [Optional].: 6
Explanation: A connection was established and immediately dropped before completing registration. Incomplete registration may indicate a device is rehoming in the middle of registration. The alarm could also indicate a device misconfiguration, database error, or an illegal/unknown device trying to attempt a connection.
Recommended Action: No action is required if this event was issued as a result of a normal device rehome..
Partha
Re: CallManager Transient Connection Attempt
Hi!
I'm getting the exact same error message (Transient connection attempt) Do you resently upgrade your tftp service? 6.0.1?
don
We've been getting the Transient Connection Attempt errors on our CM for about a month and have yet to be able to pin them down - they don't seem to be causing us any errors - but there are quite a few daily.
How did you upgrade the TFTP service independent of CM?
perhaps you mean TSP 6.0(1) ?
645
