Community Member
Calls dropped for ICS 7750
Callmanager 3.3.3sr4a Event Log:
Event Type: Error
Event Source: Cisco CallManager
Event Category: None
Event ID: 3
Date: 3/21/2006
Time: 2:53:48 PM
User: N/A
Computer: ICSCCM1
Description:
Error: DeviceTransientConnection - Transient connection attempt.
Connecting Port: 2000
Device name [Optional].: SEP000F1FA22BB9
Device IP address.: 172.16.2.31
Device type. [Optional]: 30016
Reason Code [Optional].: 1
App ID: Cisco CallManager
Cluster ID: ICSCCM1-Cluster
Node ID: 172.17.0.21
Explanation: A connection was established and immediately dropped before completing registration. Incomplete registration may indicate a device is rehoming in the middle of registration. The alarm could also indicate a device misconfiguration, database error, or an illegal/unknown device trying to attempt a connection.
Recommended Action: No action is required if this event was issued as a result of a normal device rehome..
Event Type: Error
Event ID: 3
Date: 3/21/2006
Time: 2:53:48 PM
User: N/A
Computer: ICSCCM1
Description:
Error: DeviceUnregistered - Device unregistered.
Device name.: SEP000F1FA22BB9
Device IP address.: 192.168.2.36
Device description [Optional].: SEP000F1FA22BB9
Reason Code [Optional].: 9
Explanation: A device that has previously registered with Cisco CallManager has unregistered. This event may be issued as part of normal unregistration event or due to some other reason such as loss of keepalives.
Recommended Action: No action is required if unregistration of this device was expected..
ICS7750:
MRP3-8FXS#sh controllers t1
T1 1/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
Description: Connect to T1 trunk
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20020812, FPGA: 11
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
Data in current interval (649 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
2205 Line Code Violations, 5195 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 219 Line Err Secs, 44 Degraded Mins,
219 Errored Secs, 79 Bursty Err Secs, 3 Severely Err Secs, 0 Unavail Secs
MRP3-8FXS#
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
no yellow generation
no yellow detection
description Connect to T1 trunk
If the T1 conotroller has problem or some other issue?
1 REPLY
Silver
Re: Calls dropped for ICS 7750
I think the problem is due to misconfiguration in ICS 7750
try this link for troubleshooting ICS7750
http://www.cisco.com/univercd/cc/td/doc/product/voice/ics7750/tblshoot/7750atg.pdf
109
