Calls forwarded from CCM to extension on FXS port ring twice then stop
I have a scenario where incoming PSTN calls to a 2610's FXO port are passed to an extension on CallManager 3.2 using the connection plar command.
This extension is set to forward no answer to another extension. The second extension is actually an FSX port off of the 2610.
If an analog device off that port does not answer within 2 rings the call appears to connect as if auto-answered by the 2610 or CCM. This is not an idea scenario as the fax machine off that line needs to answer at 4 rings, not 2.
If I use the connection plar command to point incoming calls directly to the extension on the 2610's FXS port instead of first going to CCM they can ring until answered by the fax.
Any ideas?
Thanks, Seth
Router Config...
cisco 2610 (MPC860) processor (revision 0x202) with 59392K/6144K bytes of memory.
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
2 Voice FXO interface(s)
2 Voice FXS interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
interface Ethernet0/0
ip address 10.2.5.6 255.255.255.0
ip nbar protocol-discovery
half-duplex
service-policy input softphone
service-policy output softphone
crypto map clientmap
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.2.5.6
voice-port 1/0/0
input gain 2
echo-cancel coverage 16
echo-cancel suppressor
no vad
no comfort-noise
timeouts call-disconnect 1
connection plar 2002
voice-port 1/1/0
no vad
no comfort-noise
timeouts interdigit 3
dial-peer voice 2002 voip
destination-pattern 2002
session target ipv4:10.2.5.4
codec g711ulaw
no vad
dial-peer voice 4 pots
destination-pattern 2000
port 1/1/0
CCM Settings...
Forward No Answer Timeout* = 10
Route Pattern* 2000
Partition = Home
Gateway/Route List* = 10.2.5.6
Provide Outside Dial Tone = Yes
Urgent Priority = Yes
Directory Number* 2002 Shared Line
Partition = Home
Calling Search Space = Home
Auto Answer = Off
Forward No Answer = 2000
Silver
Re: Calls forwarded from CCM to extension on FXS port ring twice
If the IP Phone calls 2000 and 2002 does the call still appear to be Auto-Answered prior to the fax machine answering the call?
If I pick up an IP phone and use extension 2002 or 2001 and dial extension 2000 it calls through the gateway and rings the fax line until the fax picks up. The problem only seems to happen on calls forwarded to 2000, not when you directly dial that extension.
I just tried an additional experiment. From an outside line I can call the main number which connects to the IP phone at extension 2002. Then I can answer that call and manually transfer it to extension 2000 and it works just as it should. The problem seems to only happen in the case of Call Forward No Answer calls.
173
