Calls in progress - Virtual Calls
Hi everyone
It is always viewed in cm several calls in progress, but this calls are virtual, because I can assure that there is nobody placing calls.
In our case there are always 11 calls in progress, this is the minimum calls=0 calls, if someone make one call the "calls in progress" is incremented by one.
Any ideas, how can us avoid this situation
Thanks in advance for your help
MP
Bronze
Re: Calls in progress - Virtual Calls
I am not sure which version of CM you are using, but I ran across this bug CSCdv12935 in CM3.0 which is similar to your case. This one is fixed in 3.1(3a)ES30 or later.
My version of cm is 3.2(2c) SPG.
Yes, the simpton is similar to the bug CSCdv12935, but this shouldn't apply to the 3.2.2c.
To avoid this I had to stop and start Call Manager service
MP
113
