Calls on Second BRI Channel Fail
Hi everyone, we have two ISDN BRIs configured for incoming voice calls coming into a 2811 router. If you place a call to one channel of the bri the call is successful. If you place another call to the second channel while the first call is active, the caller hears ringing for about a minute and then is disconnected. The called phone rings for a brief second and then disconnects. Debugs on the router show that a Call Release is being received by the telco. We had the telco in to test and when the second call is placed their debugs show no response from the router once the call setup is sent. Here is the bri config:
interface BRI0/3/0
no ip address
isdn switch-type basic-ni
isdn incoming-voice voice
interface BRI0/3/1
no ip address
Here is the debug from the router that shows the call release:
Dec 23 20:57:18.751: ISDN BR0/3/1 Q931: RX <- SETUP pd = 8 callref = 0x1F
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Signal i = 0x40 - Alerting on - pattern 0
Calling Party Number i = 0x2081, '9199915607'
Plan:Unknown, Type:National
Called Party Number i = 0xC1, '6137825'
Plan:ISDN, Type:Subscriber(local)
Locking Shift to Codeset 5
Codeset 5 IE 0x2A i = 0x808001039E05, 'From ', 0x8B0C, '919 991-5607', 0x9E04, 'For ', 0x950C, '860 613-7824', 0x8001018C03, 'cfb', 0x8001018C0E, 'Forw arded-busy', 0x800105800114 .Dec 23 20:57:18.767: ISDN BR0/3/1 Q931: TX -> CALL_PROC pd = 8 callref = 0x9F
Channel ID i = 0x8A
.Dec 23 20:57:18.787: ISDN BR0/3/1 Q931: TX -> ALERTING pd = 8 callref = 0x9F
Channel ID i = 0x8A
.Dec 23 20:57:18.823: ISDN BR0/3/1 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x 1F
Cause i = 0x8295 - Call rejected
.Dec 23 20:57:18.839: ISDN BR0/3/1 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x 1F
Does anyone have any ideas?
1 REPLY
Re: Calls on Second BRI Channel Fail
The cause code for the call release is 0x8295, which can be found and explained at
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a008012e95f.shtml
The least Byte has the meaning:
95 Call rejected The destination is capable of accepting the call, but it rejected the call for an unknown reason.
This cause indicates that the equipment that sends this cause does not want to accept this call.
Note: The equipment is able to accept the call because the equipment that sends this cause is neither busy nor incompatible. However, the equipment rejects the call.
So there seems to be an issue with the end device and the router. What is connected and is this device working in case only one call is in place to it?
Hope this helps! Please rate all posts.
regards, Martin
271
