You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
Bronze
calls to CME are dropped
I have back-to-back PRI setup.
CM3.3 - GW(user side PRI) - CME4(acting as network side PRI).
When calling to CME, CME drops the call and does not ring the phone that is registered to it. ISDN code Cause i = 0x8290 - Normal call clearing . Interesting thing is that in debugs called number is not displayed, only calling number.
Also, I can't dial from CME to CM3.3. CM3.3 trace gives this 'ERROR Incoming H225Setup, could not find H225D pid for incoming H225Setup' and Cause i = 0x8095 - Call rejected.
Am I missing anything in config?
CME side:
voice rtp send-recv
interface Serial1/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn protocol-emulate network
isdn incoming-voice voice
isdn outgoing display-ie
no cdp enable
GW side:
voice rtp send-recv
interface Serial0/0:23
no ip address
no logging event link-status
no cdp enable
  • Other Collaboration Voice and Video Subjects
182
