Community Member
Can 02 Ip telephones have a virtual number and ring at the same time
I have extension 5111 and extension 5112.
I want both of them to have a virtual number 3333, so if someone else dials 3333, both telephones ring and either can pick up and response.
How can i do that ? Any config in the CallManager ?
Hope someone can help.
Marcos
Re: Can 02 Ip telephones have a virtual number and ring at the s
Not sure which phones you have but you can create anotehr line on each phone with the Directory Number 3333. This will create a shared line between the two (or more) phones. When someone dials 3333 both phones will ring.
Community Member
You do need to have this dn in the same calling search space and the same partition to create the shared line appearance that rings every line.
You can also create a call pick-up group where if you hear a line ringing anyone can dial a specified number like 300 and answer the call.
Community Member
Does it care which phones i have? Is it just a CCM config issue ?
thanks
marcos
Community Member
Actually I have both 7960 and 7910 phones, I know I can create another line on 7960 , but what can I do with 7910 ?
thanks
Marcos
103
