Can a Gatekeeper do call admission control between IOS H.323 GW and Call Ma
Can a Gatekeeper do call admission control between IOS H.323 GW and Call Manager ?
is yes, does anyone have the url site on how to configure it .
1 REPLY
Re: Can a Gatekeeper do call admission control between IOS H.323
Yes it can,
You'll need to register your call manager and gatway to teh gatekkeper using different local zone.
You can the use the bandwidth command under the gatekeeper configuration to specify the bandwidth allowed between the two zones. Gatekeeper can use additional command “bandwidth” under the gatekeeper mode for call admission control. A bandwidth in KB/s is assigned to each remote zone, session or interzone and deduction is done per call with respect to the codec of choice and GK calculations.
Bandwidth used for deductions in Gatekeeper CAC
Codec and BW GK BW deductions (KB/s) Actual BW for voice call (KB/s)
G711 and 64Kb/s 128Kb/s 88Kb/s
G729 and *KB/s 16Kb/s 26.4 KB/s
***Note*** the actual bandwidth should be used to determine the number of possible calls between zones based on the WAN bandwidth available. When this Number of possible call is determined, multiply this by the Gatekeeper Bandwidth deduction per codec/call to determine the bandwidth figure to put under the bandwidth configurations below.
(config-gk)# bandwidth?
interzone Configure max bandwidth allowed from zone to all other zones
remote Configure max bandwidth allowed to all remote zones
session Configure max bandwidth allowed for a session in a zone
total Configure max bandwidth allowed for all calls in a zone
The recommendation is to use total, which accounts for all possible call from any where via the gatekeeper to a specific zone which is also with respect to the WAN bandwidth available for incoming call.
see this url for additional config help
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_configuration_example09186a0080094ac3.shtml
Hope it helps
Tola.
163
