Can Cisco IOS Gatekeeper do call admission control for IOS H.323 GW & CM ?
Can Cisco IOS Gatekeeper do call admission control between Cisco IOS H.323 GW & Call Manager ?
I have a few CIsco IOS gateways and Call managers in different countries.
Can i use jst one Gatekeeper to do call admission control between the devices ? if no, any recommendation.
Do u have any configuration on this setup.
Re: Can Cisco IOS Gatekeeper do call admission control for IOS H
Hi yes of course you can, run the correct IOS register the H.323 gateway with the GK set up the zone and bandwidth and whamo your cooking with gas.
session target ras on Voip dial peer .
Allan
There are plenty of links available.
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a00800a8928.shtml#8
interface Ethernet0/0
ip address 172.22.1.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip id GK-A ipaddr 172.22.1.3 1718
h323-gateway voip h323-id GW-A1@abc.com
dial-peer voice 1 pots
destination-pattern 512.......
direct-inward-dial
port 1/0:23
prefix 512
!-- On outgoing calls through POTS dial-peers,
!-- all explicit digit matches are dropped, which is the reason
!-- for adding the prefix 512. This has nothing to do with
!-- technology prefixes.
dial-peer voice 2 voip
destination-pattern 972.......
session target ras
!-- Uses RAS messages (GK) to get call setup
!-- information.
gateway
Hi Allan,
thanks for yr help. I read somewhere that you cannot use gatekeeper to do call admission control between IOS H.323 gateways and Call manager gateways . I could not find that link anymore.
Do you have any experience in using one gatekeeper to do call admission between Cisco Call Manager and IOS H.323 gateways.
David
251
